Starting a fresh build - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2012, 01:10 AM
What started as a cheap woods truck (87 k5 blazer) has graduated from cheap. I need a lil advice this is my first motor build by myself. I have learned over the years that asking for advice can save ya alotta money and headack. I got the motor all torn down it is already 30 over and looks good. Here's is were I need advice ,what crank would be the best for the money I'm not rich but I only wanna do this once. I'm mostly gonna drive the truck to and from my hunting camp and play in the woods. But if it's like any of my other projects i will probably go all out and build a bas *** motor. Any advice would be appreciated.
Old 08-02-2012, 01:29 AM
vinniekq2's Avatar
use the stock crank.what are you expecting from the engine? A blue printed near stock engine should out last the truck
Old 08-02-2012, 05:29 PM
Use the stock crank as in the actual one that came out?(my buddy from the machine shop came and looked at the block and pistons and said they looked good jus to clean them with actual pieces of rings and put new rings) or jus order a stock one if so what brand do u recommend ? I plan on putting some aluminum heads and a good intake. My buddy that was supposed to know what he was doin and helpin me quit working for me so I'm hopin with help from this forum I can build something pretty bad a@$ but reliable.so any help or suggestions is appreciated.
Old 08-02-2012, 06:29 PM
vinniekq2's Avatar
no need for aluminum heads.use a good stock crank from manufacturer.Blue print the engine and balance.some bolt ons are ok.thats all you need
Old 08-02-2012, 07:44 PM
The engine is a 95 I was told these were not the good heads is that true? What year heads should I look for ? I was told I could get some stock vortex heads ? I thank everyone for the input
Old 08-03-2012, 11:46 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
It is hard to beat a GM crank. Eagle and Scat cranks are marginal quality. If you want a decent aftermarket crank you are going to need to spend a grand on something like a Callie's crank. Is there something wrong with your current crank? My local machine shop sells used reground GM cranks for about the same price as a new Eagle crank. Go GM!
Your existing crank should be inspected by a machine shop. They need to look at the rod and crank journals for roundness and scoring, the thrust flange for scoring, and magnaflux the crank to see any cracks.
Why do you want aluminum heads? When you say "woods truck" I think this is a hunting rig. Are you trying to make a big horsepower mud bogger? Iron heads would be fine.
The block is a '95, so unless this is a crate engine, it is an LT motor. I am not sure if the older Gen 1 (and Vortec) heads will work. LT motors had reverse flow cooling and think there are some extra plumbing for steam on those.
Old 08-03-2012, 07:46 PM
farmwalker's Avatar
Use the old crank. Unless your building Strip only dragster or your stroking it use the old one. Cause by the time you turn a 400 crank down to a 350 main you would have spent the same to buy a new eagle or scat crank.
383 fresh build issues... imagine that big_c_snow Engine 6 05-01-2012 08:37 AM
Question on blow by on a fresh build Ignitrous Engine 6 06-13-2011 12:01 PM
Fresh 383 build some rockers not getting oil palmertree Engine 12 08-14-2010 10:11 AM
406 Fresh Build Distroyed Cam, Help BIG E 86 Engine 2 03-15-2010 07:07 PM
problems on fresh build 65Guera Engine 30 06-17-2005 09:20 PM
