Your engine does not have to run hot to boil the gas from the carburetor. Try a heat shield to prevent the gas from boiling away after you shut your engine down.
Edelbrock 9266 Edelbrock Heat Insulator Gasket. Holley and Mr.Gasket sell them also. Be sure to have your fuel pressure set at 5.5 psi. Another problem you could have is the way you have your timing curve setup. You might have your throttle blades open to much uncovering the transfer slots. You must remove the carburetor to adjust this setting. To start, the primary is adjusted to have .020 of the transfer slot showing. The secondary transfer slot will be closed. You will not have to open this unless the idle is too low. Reinstall the carburetor and start the car to see what rpms it idles at. 850-900 rpms would be good for idle after it is warmed up. You will need a timing light with an advance knob. Set the knob to zero. Unplug the vacuum hose from the distributor and plug it. Set the initial timing at about 10*-12* BTDC. If the idle is too low advance the timing until your rpms read 850-900. This might take around 16* BTDC. Then have someone hold the rpms to about 3000-3500. Point the light at the scale and turn the the knob on the back of the timing light until the line on the balancer aligns with zero on the scale. You will want 36* on the timing light. Turn the distributor until you get 36* then lock the distributor. Read this article it has all about setting your timing curve and your carburetor's transfer slots.
http://www.crankshaftcoalition.com/w...EI_distributor Here is the link to the Edelbrock 1406 manual
http://www.edelbrock.com/automotive_...404_manual.pdf
