Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - starting issues
Thread: starting issues
Old 12-26-2012, 05:48 PM
hcompton's Avatar
hcompton hcompton is offline
Old & Furious
Adjust the idle mixture screws on the front of the carb while its hot. With the choke hooked up it should still fire off when cold then idle down when hot.
But this only happens when the choke is hooked up without it runs normal? Maybe the choke needs to be tweaked or is not hooked up properly.
