Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - starting issues
Thread: starting issues
Old 12-26-2012, 06:53 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
Originally Posted by thefox View Post
hello guys so today i checked for leaks and hooked up the choke. got in the car turned the key and she fired right up it idiled at 2000-2500 for ten min and never kicked down i checked for power at the choke on the carb and there is power now its been 15 min still no kick down on idle so i got in it took it for a boot for 5 min got home still high idle like 1500-1800. any clues or tips to get her to kick down when she is hot. thanks
What position is the choke plate in?
(It should be wide open when the engine is at operating temperature.)
If it's not ... is there still power at the choke cap with engine running?
12V or 15V?
Have you tried adjusting (rotating) the choke cap so that the choke IS open at operating temp?
