starting problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2011, 09:44 PM
A Todo Madre o Un Desmadre
Last journal entry: 700r4 rebuild
starting problem
I have a 1992 firbird and its been running fine I try to take care of it as much as my money allows..I parked it and when I went to go turned it on it wouldn't start at all. My car hcranks over but won't start up... it has done this b4 and it was the coil well when I opened the hood the coil was smoking. I thought it just went bad but when I replaced it. It still wouldn't start and when I touched the coil it felt like it was starting to heat up bad. Any tips or sugestions would be apriciated.
Old 04-22-2011, 10:29 PM
The mobile view is crap
Check the ground wire to the cable, check the engine ground to frame/body ground. Obviously you have a bad ground some where if the coil is getting smokin hot.
Old 04-23-2011, 12:17 AM
did you check to see if it was getting spark?
Old 04-23-2011, 06:26 AM
I ll check to see if its grounded bad but I don't think it would be since my car would start fine all the time its just this one time that it didn't start up. I already checked the spark and I'm not getting nothin
Old 04-23-2011, 06:30 AM
LATECH's Avatar
It sounds like a bad ignition module or a wire from the coil to the module pinched or melted and shorted to ground.
The coil should not have a path to ground until the crank signal turns it on and off. If it is heating up then it is grounded somewhere and staying on will heat it up. I would look the wiring over real good.If you find nothing , suspect the module.But check the wiring first and be thorough, you dont want to spend 75 bucks on a module if you dont need it.Use it for gas
Old 04-24-2011, 06:01 PM
well i took a look and well i guess it was a ground thing because i disconected the ground from the fire wall and ground it down to clean it up and sure enough it fired right up but... every time i put it in reverse or in 1st gear the darn thing dies on me
Old 05-16-2011, 07:41 PM
problem solved or so i thought
Well I found out what was wrong wit the car the a wire from my tachometer was grounding out...it ran fine but then my car turnd off while it was running ...it wouldn't turn on...I let it sit for 3 days and it turnd on when I went to try and turn it on. I don't want to take it out for the fear of it turning off on me again wat could be wrong wit it?
Old 05-17-2011, 04:27 AM
EOD Guy's Avatar
You probably have a wire who's insulation has worn through over time, you stated the tach has shorted out......
350 SBC starting problem richnkatie1993 Hotrodding Basics 3 01-15-2009 09:14 AM
Starting Problem JBIG Introduce Yourself 1 07-22-2007 12:23 AM
Starting problem flcajun Engine 2 10-05-2006 12:25 PM
Problem starting 65Guera Electrical 26 08-12-2005 06:30 PM
Problem starting dion Engine 11 12-24-2002 06:48 PM
