starting problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2011, 01:12 PM
chevy c20's Avatar
chevy c20
starting problem
when i turn the key on everything comes on but it won't start the engine.
i need some tips on how to solve this problem
Old 04-23-2011, 02:39 PM
T-bucket23's Avatar
Wiki Edits: 26
You need to supply all the information about the vehicle and what you have done so far.
Does it crank and not start or does it not crank at all
Chet
Old 04-23-2011, 04:09 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Start by cleaning the battery posts. Remove cables, clean, replace.
Wiggle the shifter while trying to crank. Could be a bad NSS. (Neutral start safety switch)
Run a jumper direct from the battery + to the starter crank terminal. That's the small terminal on the starter solenoid. If that doesn't work the starter is bad.
If that works the ignition switch is bad or NSS or a bad connection is the crank circuit (purple wire on GM).
vicrod
Old 04-23-2011, 10:29 PM
chevy c20's Avatar
chevy c20
starting problem
i turn the key and nothing happens
Old 04-24-2011, 04:54 AM
EOD Guy's Avatar
Do as Vicrod suggested
Old 04-24-2011, 01:07 PM
chevy c20's Avatar
chevy c20
starting problem
i did that and it just smoked the starter motor so it the Neutral safety switch
but I changed that not to long ago and i think that one is bad to but thanks for all the advice .
Old 04-24-2011, 07:01 PM
EOD Guy's Avatar
run a jumper and bypass the NSS and see if it works.
Starting Problem JBIG Introduce Yourself 1 07-22-2007 01:23 AM
Starting Problem Classic34 Electrical 2 12-31-2006 07:43 AM
Problem starting 65Guera Electrical 26 08-12-2005 07:30 PM
problem starting when hot jtrimmer Engine 4 05-19-2003 05:00 PM
Problem starting dion Engine 11 12-24-2002 07:48 PM
