Starting problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2008, 07:42 PM
abe abe is offline
Starting problems
I have a starting problem on my big chevy. It used to start up right after it warmed up with no problem. but then one day i over advanced the timing and then it had a hard time starting. So i reset the timing and restarted the engine and ever since i over timed it things never was good as it used to be. I tried cleaning all connections and even the battery. Do u think my over advancing the timing affected something else i am not aware of. It turns over really slow. It used to start on 1 click after it warmed up now its like just dragging. What do u think it is..
Old 09-05-2008, 08:00 PM
automotive breath's Avatar
It's likley the starter solinoid got overheated from the advanced timing,
replace it and I suspect things will be back to normal.
Starter problems.....again, and again zipfactor Engine 32 01-05-2012 07:50 PM
Relay issue? Starting problems 2ManyCars Electrical 4 08-06-2005 04:13 PM
starting problems after MSD SBC S-10 Electrical 4 07-18-2005 01:23 PM
starting problems 29Roadster Electrical 3 10-12-2003 09:11 PM
Starting Problems rehjr0219 Engine 9 02-12-2003 06:35 PM
