starting problems need to know today - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2008, 08:08 PM
d&c repairs it all's Avatar
what does it mean when you try and start the truck and it just spins like neeeehennn but, the wierd thig is that it was working right before that
its a ford 390 "69" if that helps
have stuff to do tomarrow
thank you
Old 12-28-2008, 08:33 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
The throw out part on you solenoid is not working sounds like.
Old 12-28-2008, 09:20 PM
start problem
could be, it sounds like the starter is spinning, but it won't connect to start. Definitely not the battery. Thanks, JC
Old 12-29-2008, 03:35 AM
easy job the solenoid shold be mounted to the fender well check the connections first
Old 12-29-2008, 08:54 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
If the starter spins but does not engage then you have a bad starter bendix. Replace your old bendix with a new bendix or starter drive.
Old 12-29-2008, 09:35 AM
scr8pin_f100's Avatar
*WARNING* Idiot in Training!
Last journal entry: Jag Front Clip
yup..I concur that the problem is with the starter..But make sure before you take it off that you don't have a bad spot on your flywheel (missing teeth)..I've had that happen to me...If that is the case, turn the flywheel until you see teeth...
good luck!
Old 12-29-2008, 11:05 AM
reply on starter problem
thanks for the good advice, we're working on it now. check you later,
JC
Old 12-29-2008, 02:10 PM
T-bucket23's Avatar
Wiki Edits: 26
If that is a 69 ford starter then if it spins at all the solenoid is good. Those depended on the magnetism from the armature when energized to pull in the drive. under the cover that is on the starter there is a metal arm that gets pulled in when the starter gets power. These were known to stick. The bendex could also be bad. This is an easy starter to repair as there is no solenoid on it.
You can test it with a set of jumper cables an a battery. Connect the + to the stud and the minus to the case of teh starter and see if the drive shoots forward and spins. If it does then you need a bendix if not the actuator arm is binding. Used to see this a lot if the flywheel cover was missing.
Chet
starting problems after MSD SBC S-10 Electrical 4 07-18-2005 01:23 PM
Starting Problems... arch Engine 12 10-30-2004 05:21 PM
TBI Starting problems punk1c5040 Electrical 6 10-29-2004 06:20 PM
Starting Problems rehjr0219 Engine 9 02-12-2003 06:35 PM
