Fore-ever Fours.
Building a Four can be expensive if go full out. I have a 22 T speedster. The more I looked at an A crank and overhead valve conversiona and the $ $ required , I decided not do a whole lot. I was teaching the Auto engine classes at the college so I hauled in 6 model T engines I had collected. Once you get a machine set up , the machine time isn't that long. I picked out the best block, bored 60 over, new aluminum pistons, new 3/4 cam , timing gears and machined for adjustable lifters, decked the blocks on the head machine, faster on a little engine and milled all the stock heads to remove water corrosion. balance all the rods and pistons, You don't have to be the fastest to still have fun. but I did come in no 11 out of 70 cars.
![]() ![]() Dave W Last edited by Irelands child; 12-17-2012 at 04:24 PM. Reason: Spelling |
Thanks, to be honest I think I see the gap here between my expectations and the majority. I would certainly not need to go full out with the engine. If it could cruise at highway speed I am more than happy. The objective here is to cruise... A little extra pep would be nice but certainly nothing major. As per Dave's posts, I will continue research... Thanks again, Paul |
Modified A's
A mild A , B or C engine would still be fun and there are several different transmission options, reworked modern transmissions to work in an A, good for cruzing. , I have an antique Moore gear box behind my T transmission, I now have 4 foreward and 2 reverse speeds in the T. originally a T only had 2 foreward speeds.
May I suggest going resto-rod with that car..that is stock body with late model running gear..Boxed "A" chassis..disk brakes all around..Perhaps the turbo 4 as suggested..Main thing if you have not built a ground up car before is keep it simple..Even that buick you have could work..just do a rebuild and some dressy pieces and you are good to go..
Sam
I am certainly leaning towards leaving the body pretty much as-is for now and simply removing the fenders/running boards. I dont particularly feel like there is a need to do massive surgery to it and will probably 'tweak' it over time as I enjoy it, which is my primary objective. I will try to dig out some photos of an original A with just fenders removed to see what sort of rake/look that gives but may be removing them in the next week so I will know soon enough... Boxing the frames is on my must-do list and will likely done in the next month or two. Paul |
| starting new project | josiecogburn | Introduce Yourself | 6 | 09-26-2012 05:10 PM |
| New project starting soon!!!!!!!! | NEW INTERIORS | Hotrodders' Lounge | 33 | 11-04-2008 07:18 PM |
| Starting a new project | PackratMT | Introduce Yourself | 3 | 08-17-2008 04:55 PM |
| starting my first project. | popman886 | Introduce Yourself | 7 | 03-19-2008 03:23 PM |
| just starting a project | willysboy | Suspension - Brakes - Steering | 4 | 11-04-2003 09:36 PM |
