Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Starting on Surface Rust - Several Questions...
Old 09-22-2005, 10:23 PM
kenseth17 kenseth17 is offline
Many on here recommend SPI on here that barry K sells who is also located in GA. I don't have the link offhand, but I am sure someone will have it soon. I've never used spi yet myself, but they are suppose to be good products at a good price. If not your local paint supply store will carry it, its not too high priced, will in some of the upper lines like ppg dplf it is a little pricey, but there are also lower lines like dupont nason and ppg omni. If you want to be absolutely sure of compatability you should use the same line is the paint you are going to use, but I've used omni epoxy primer many times under marhyde 2k urethane primer and different paint lines without a problem. I still have some eastwood catalogs from the 80's when I got there catalogs around somewhere. Never did order from them though, they seemed a bit pricey on many things compared to others.
