starting used engine after 8 months ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2012, 08:32 PM
Cape Cod Bob's Avatar
Should I do anything or will it be ok ?
Old 09-11-2012, 08:36 PM
spinn's Avatar
Change the oil and start it. Check all the fluids and fuel system first. Then look for animal nests. If it is a built engine you might want to prime it.
My 323 mopar sat for 6 years and it fired right up. My 440 has a big cam and when stored the rocker shafts are released. Otherwise no problems.
Old 09-11-2012, 09:19 PM
DoubleVision's Avatar
When you fire it up cycle it as if it were new. Run it around 15 minutes around 2000 RPM. This assures the cam gets plenty of lube which will prevent it from wiping out a few lobes which is a common occurance on engines that have sat for a given number of time and not cycled upon restart.
Old 09-12-2012, 03:19 AM
JeffB's Avatar
You can go to your local Autozone and get a loaner oil pump primer just put down a deposit and when you return it you get your deposit back.
The Following User Says Thank You to JeffB For This Useful Post:
Jano (09-13-2012)
Old 09-13-2012, 05:13 PM
Jano's Avatar
Last journal entry: Model A Tudor: Back From Randy's
My 302 started right up after sitting for 12 years.
Used an oil pump primer on electric drill to build up oil pressure. Then turned the engine over with starter motor while spinning the oil pump with the drill to make sure oil was getting to the bearings.
Put the distributor back in and fired it up.
Old 09-13-2012, 08:04 PM
OK, so I changed the oil and filled the new filter first. let the electric feul pump fill the carb and released the choke and the darn thing started better then fule injection. Came right up to 2000rpm and I left it there for 10 minutes. before kick down to idle.
Absolutly no lifter noise ,got pressure immediatly. . I love this motor .
Thanks for all the tips.
Starting gas engine with starting fluid Bill Riese Engine 15 03-18-2011 12:13 PM
Need help starting engine Pontiac engine muzzfactor Engine 5 05-28-2007 10:43 PM
Starting an engine A_Chevy_Man Engine 4 08-21-2006 09:35 PM
Clear coat starting to dull after 3 months help please anthonycn Body - Exterior 9 09-02-2003 02:22 PM
starting up car after 16 months smallz Engine 5 05-29-2003 02:16 PM
