Starts but won't run
I have a 1927 Ford T Roadster. I took a 2.2L motor out of a 1998 Chevy S10 pickup. I have the computer, body control module but I do not have the stock column or the ignition or the key or the passlock module in my possession. It starts and runs for about 2 seconds. I have checked the fuel injectors with a noid light and it is dropping out the injection circuit. I believe this to caused be the passlock theft system in the computer. How do I get around this?
You need the ignition cylinder out of a 98 S10 (MRS magnetic resistor start) or a module to bypass the ignition. Module can be picked up from any installer who does remote starters on vehicles.
Starts won't run
I already purchased a bypass module and installed it. The module needs a code to read and without the ignition there is no code to read. I have been told there are between 13 to 15 codes.
| how to run heat riser tubes? | matt167 | Engine | 1 | 09-12-2006 05:49 PM |
| Painless Electrical in 1959 Chevy Apache | Craig legacy | Electrical | 7 | 06-24-2006 12:36 PM |
| wiring diagram | samh | Electrical | 2 | 02-07-2006 06:28 PM |
| 200 photos from Temecula Rod Run 2003 | xl1ken | Hotrodders' Lounge | 5 | 02-20-2003 06:15 PM |
