Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - static problems I think
Old 02-11-2008, 07:33 PM
motomonkey motomonkey is offline
Are you remasking everything after you wet sand and before you flow coat? if you are using the same paper/tape that was used in on the first go around with the clear, sanding and then not repapering and masking you could be blowing out all the sanding mess. is this happening only on the flow coats? Spies-Hecker makes an anti-static final wipe that might help out!?!?!
