Static VS Dynamic compression (cam selection) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-24-2013, 01:25 PM
For the record this cam did decently. I was told my many others it would run horribly. Ran it all year roughly 100 passes. Few thousand street miles.
As expected, Idle is very tame with no lope. Cruise is the same. Launched the car at 3400-3600 off the 2-step and trans brake. Boost cam on hard and fast. Finished the year up w/ 24lbs of boost on off the t-brake and boost peaking at 23.8 during the run. 15* of timing. Drove it to and from the track all year on drag radials. Car cruises right around 70 at 2500-2600 with the 3.10 gears and 28" tire.
For a $98 cam I'd say...It's a worker!
9.04 @ 151.
5.81 in the 1/8th.
1.38 60'.
Well over 800whp going by weight and trap speed. All on a $220 OEM bottom end, hardware and all.
  #17 (permalink)
Old 10-24-2013, 07:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Now that's my idea of hotrodding! Good job and I'd personally like to see a lot more like it instead of the "big bucks, gotta have all the bells and whistles" poser rides that can't get outta their own way.
The Following User Says Thank You to cobalt327 For This Useful Post:
techinspector1 (10-25-2013)
  #18 (permalink)
Old 10-25-2013, 07:06 PM
Thanks... here was the actual 9.04 pass launch.
  #19 (permalink)
Old 11-02-2013, 08:48 PM
Make that 8 seconds...
Static CR vs Dynamic CR seandiddy Engine 6 06-28-2011 04:51 PM
How much static compression for this cam? z-adamson Engine 16 06-26-2011 01:42 PM
Cam Selection and Dynamic CR Arcuden Engine 8 03-23-2008 11:03 AM
dynamic compression k-star Engine 8 06-25-2004 09:33 AM
camshaft selection and dynamic compression blndweasel Engine 7 03-13-2004 07:19 AM
