Static VS Dynamic compression (cam selection) - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2013, 10:43 AM
Am I using this dynamic compression calculator incorrectly?
The static seems correct form what I’m told. My LS series 5.3 Motor should be about 8.5:1
I chose an odd ball cam with almost no overlap. The engine is a street motor and will have a small turbo and high back pressures so I didn’t want a cam with a lot of overlap as the exh pressures will be higher than the intake pressures by quite a bit.
Anyway… What I’m trying to figure out is why this calculator is dropping my dynamic compression down to the 7:1 range? I was assuming a cam with little to no overlap wouldn’t loose much in terms of dynamic compression. I could see a cam with a ton of overlap and duration bleeding off compression, but I thought I wouldn't lose much compression going with this cam.
Any thoughts? Am I doing this wrong?
Cam specs (ZR1 OEM camshaft)
211/230 @.050 valve lift and .558/.552 lift with 1.7 rockers and a 122.5 centerline.
Old 06-04-2013, 11:40 AM
Ed Iskendarian once said: "The intake closing point is the most important valve event."
Example: My Comp camshaft has 39* valve overlap with a intake closing event of 58* ABDC.
The static compression ratio is 10.2: and the dynamic compression ratio is 8.5:1. NA dynamic compression ratio of 8.5:1 is the limit for 93 octane pump gas.
How is your valve overlap calculated? The valve overlap must be calculated using the seat to seat time or duration at .004" - .006" valve lift.
Degrees intake valve open + degrees exhaust valve close = degrees valve overlap.
Old 06-04-2013, 12:06 PM
Banned
It all looks right, your IVC is 46.5 degrees, what did you expect? It should be a decent turbo cam but be sure to run a large enough exhaust housing.
Old 06-04-2013, 12:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What calculator is that? Using the United Engine & Machine Co. Incorporated calculator I'm seeing about the same- maybe a tick lower but that's due to how that particular calculator works.
Old 06-04-2013, 12:16 PM
It was an .XLS spreadsheet a friend sent me. I don't have a link. I'll try to attach it if anyone wants to play with it.
Running a t4 1.10AR t4 housing with an 83mm wheel.
I don't mind the lower compression, I plan to run alot of boost. Using e85 for fuel though so 7:1 seems a bit on the conservative side.
Thanks all...
Old 06-04-2013, 12:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks for the link.
Is this a race-only deal or will you be driving it on the street a lot?
Old 06-04-2013, 12:40 PM
Just to and from the track mostly. Occasional cruising.
Heres the build thread if your bored...
79 RX-7 LS 5.3 Turbo Build
Old 06-04-2013, 12:47 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That's a bad-*** ride! The only 'iffy' part I see is the lightened NASCAR-type rear gear- will it take the launch w/slicks?
Old 06-04-2013, 12:56 PM
Thanks.
We'll find out...
I read about a few guys using them on Yellowbullet.com. They were also running heavier cars so I'm hoping I'll get away with it.
They are made of the shock resistant 9310 high impact steel. From what I hear it should be as tough as a standard gear even lightened. It's a soft metal though so It will wear quickly if I put a ton of street miles on it. I figured for $130 I could give it a shot. Local track is 15 miles from the house.
Old 06-04-2013, 01:37 PM
The static seems correct form what Iím told. My LS series 5.3 Motor should be about 8.5:1
I chose an odd ball cam with almost no overlap. The engine is a street motor and will have a small turbo and high back pressures so I didnít want a cam with a lot of overlap as the exh pressures will be higher than the intake pressures by quite a bit.
AnywayÖ What Iím trying to figure out is why this calculator is dropping my dynamic compression down to the 7:1 range? I was assuming a cam with little to no overlap wouldnít loose much in terms of dynamic compression. I could see a cam with a ton of overlap and duration bleeding off compression, but I thought I wouldn't lose much compression going with this cam.
My DCR calcualtor shows a 6.62 against a SCR of 8.39. I'm guessing that there's another 15 degrees which I added on to get to the closing point of .006 which will be exacerbated by the 1.7 rocker ratio holding valves open more per degree than would be seen with a lower ratio rocker like those of the GEN I SBC. Given that you'll have a lot of blower pressure against the rising piston this may not be all that bad. The weakness of huffed motors is the cam effects when there is no to little intake pressure. DCRs in the sixes are pretty common with competiton motors running a lot of intake pressure which you say is an operational goal.
Bogie
Old 06-04-2013, 01:38 PM
techinspector1's Avatar
Wiki Edits: 326
Couple of questions....
1. Is that a fuel filter hose-clamped to a crossmember and lines run next to the driveshaft? If so, I'd send you home for a re-do.
2. Where's the rest of the cage? I don't see a windshield bar or halo bars. You can't go quicker than 10.00 in the quarter or faster than 135 with a rollbar.
3. You are going to build a metal cover for the cell, right?
Old 06-04-2013, 01:42 PM
Banned
more than once...
And I would definitely watch the fuel line, fluid control means a lot even when your car isn't crashing and just running down the track as it should.
Old 06-04-2013, 02:03 PM
Bogie
Man if the DCR is that low Iím surprised it gets out of its own way. Iíve had it out and about locally and wastegate turned down as much as possible. Even out of boost with the 3:10 gear and 29Ē tires it accelerates decently. Felt pretty strong at 9lbs. Assuming it stays together I had planned to crank the manifold pressure up to the mid to upper 20ís once I get the tune all dialed in.
Old 06-04-2013, 02:19 PM
Appreciate the heads up.
That picture isn't the best. The rx7's had a high spot there where the factory storage bins were. Is there a regulaton for how close the fuel lines can be to the driveshaft? I didn't think mine were that bad? I'll look again and get a measurement. They are very close to the same spot the OEM lines were. Lines are also SS. The filter is up out of the way (again hard to see).
Yes, the steel box around the cell does have a cover.
I know I need to address the cage. Trying to get the car road worthy and tagged at the moment. I had planned on dialing in the suspension on low boost to get a general feel for the car. Shouldn't break 10.0 on low boost. Hell if the DCR is really 6.5:1 It may not break 10's without some serious pressure.
Old 06-04-2013, 03:16 PM
Banned
that DCR isn't as low as it sounds. There have been MANY engines built that way from the factory from way back when, and they all did fine.
Don't confuse SCR and DCR, there's a big difference.
Static CR vs Dynamic CR seandiddy Engine 6 06-28-2011 04:51 PM
How much static compression for this cam? z-adamson Engine 16 06-26-2011 01:42 PM
Cam Selection and Dynamic CR Arcuden Engine 8 03-23-2008 11:03 AM
dynamic compression k-star Engine 8 06-25-2004 09:33 AM
camshaft selection and dynamic compression blndweasel Engine 7 03-13-2004 07:19 AM
