steam out of air cleaner? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2006, 05:57 PM
hi everyone, ive got a 70 skylark, 350 2-bbl, all stock, and ive noticed that after a 15 min drive or so and i pop the hood, there is some steam coming out of the air cleaner. is it possible that there could be a coolant leak somewhere? or is it just overheating? It is not a significant amount of steam, but it just sort of slowly wisps out of the snorkel part. thanks for your help!
Old 12-14-2006, 06:07 PM
poncho62's Avatar
Wiki Edits: 5
Are you sure the "steam" is coming from there?.........Is there a nearby hose?
Maybe, with a pinhole in it?
Old 12-14-2006, 06:25 PM
Sounds more like the carb is leaking fuel into the engine. It wont be very much as you dont have fuel pressure any more but still enough to see what looks like steam. Usually after an engine is warm you can remove the air cleaner with the engine off and pump the accelerator and see the same steam appearance. The heat of the engine will vaporize the fuel and since you dont have any vacuum pulling it into the engine it will rise.
Air Compressor Types- What do you have? ChevelleSS_LS6 Garage - Tools 135 11-01-2014 08:49 PM
Fresh air respirators 2stroketurbo Body - Exterior 26 02-15-2007 06:41 PM
What Size Air Cleaner for Mild 350 JohnTN Engine 1 12-11-2006 10:05 PM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 05:52 PM
Air Cleaner Question Jag Daddy Engine 3 04-18-2003 05:35 PM
