spray foam.
The family farm has a 40 x 60 : metal culvert type building with sprayed on foam I wondered about the fire safety since it is exposed. My wife's cousin used to build wood stoves in the winter, it never caught on fire with all the welding they were doing. We used to heat it with a kerosene type torpedo heater to keep the produce from freezing until it was sold. Cost to heat VS sales potential VS donate what's left to the Food bank and take the tax deduction.
If the spray foam is approved for occupied buildings, then it must be fire rated.
Trees |
drywall covered
in the old days some of the foams had to be completely covered with 1/2 drywall. the nice thing about the foam is it seals out all the air leaks. , A cousin had the interior of his garage spray sealed , I think his buddy sprayed what was left at the end of the day, then later netted and blow in before drywall.
Metal Building Insulation
There are several ways to insulate a metal building, depending on the R value of the project. Insulation usually comes in 3", 4" or 6" thickness this will depend on what R value you are seeking, I would recommend http://insulation.org to find the exact R value suitable for your project. If you are looking for a more custom insulation to reach an R value of lets say R30, I would recommend contacting a custom metal buildings company *********************************
Last edited by OneMoreTime; 02-21-2011 at 09:02 AM. Reason: Advertising. Please see: commercial posting guidelines. |
For anyone that finds this thread looking for insulation info... if you live in a humid climate like I do, steel buildings sweat/condensation and mold can be a problem when it gets in between fiberglass insulation. The best insulation for a metal buiding is closed cell spray on foam. It sprays on and seals water tight and forms a barier so condensation can't get through. It's expensive, I've been doing a lot of looking around for DIY spray on foam kits for my steel building... and for 2000 sq ft area it looks like it could cost me about $3000... But I've gone this far with my "dream shop" and after waiting till I retired for a nice shop, I'm going to do it right. Closed cell foam actually works better than the fiberglass batting.
NOTE: Open cell spray on foam won't work, it won't seal out the moisture and you will end up with a big mess and a big waste of money. Just my 2 cents... for what it's worth. |
| Recent Garage - Tools posts with photos |
| Welding Stainless Steel to Hot Rolled Steel? | Rambo_The_Dog | General Rodding Tech | 11 | 05-07-2007 10:05 AM |
| insulation | old40ford | Body - Exterior | 1 | 01-11-2007 11:30 AM |
| Steel building questions | widerberg | Garage - Tools | 11 | 11-27-2006 12:03 PM |
| DIY - custom steel cowls, for a steel hood? | Woogeroo | Body - Exterior | 1 | 12-18-2005 07:43 PM |
| insulation | huffed6 | Interior | 4 | 08-13-2002 01:59 PM |
