-   -   Steel Wheels (http://www.hotrodders.com/forum/steel-wheels-137829.html)
ss396si 04-29-2008 09:50 AM
Steel Wheels
How do you identify 15" chevy steel wheels?
Houston54 04-29-2008 10:20 AM
The bolt pattern for GM wheels is 4 3/4" whereas most of the other makers use a 4 1/2" pattern. To determine what the pattern is you measure from the middle of one hole to the bottom edge of the diametrically opposite hole.
This shows how to do that:
http://www.tirerack.com/wheels/tech/....jsp?techid=92
ss396si 04-29-2008 10:57 AM
i want to make sure my dog dish center caps fit for my 69 chevelle.
Buick,Pontaic,Olds and Caddy had different bolt pattern then Chevy.
