-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Steel Workbench (http://www.hotrodders.com/forum/steel-workbench-128173.html)
Twisted Minis 11-14-2007 12:48 AM
Steel Workbench
Always wanted a welding table, or steel workbench. Getting a new (read used) toolbox freed up a lot of space and I decided to build one.
http://www.hotrodders.com/journal_ph...1943296520.jpg
It needed adjusters since half of it sits on a mat.
http://www.hotrodders.com/journal_ph...1943296521.jpg
http://www.hotrodders.com/journal_ph...1943296522.jpg
http://www.hotrodders.com/journal_ph...1943298250.jpg
I also at the same time built a small cart for my new plasma cutter. I got tired of dragging it across the ground with a tangle of wires.
http://www.hotrodders.com/journal_ph...1943298251.jpg
And here it is complete, with my plasma and my new Milwaukee HD Chop Saw tucked underneath.
http://www.hotrodders.com/journal_ph...1943298252.jpg
Nice and neat.
And heres some parts for my current project.
http://www.hotrodders.com/journal_ph...1943765550.jpg
dinger 11-14-2007 09:17 AM
Nice work, TM. Of course by now, I wouldn't expect anything less. :D It looks heavy duty enough to do anything needed. Dan
schnitz 11-14-2007 07:46 PM
How thick is the top? Got anything you might do different?
In a while, Chet.
Twisted Minis 11-14-2007 08:34 PM
The top is 3/16" that I got off the remnants rack at the local steel yard.
So far after using it I wouldn't change anything, but I know I will be adding a simple touch to it soon.
Kevin45 11-15-2007 03:09 AM
With all the steel you weld daily, the Chinese will have a shortage. Great table. Thanks for sharing the info. Now all I gotta do is learn to weld :rolleyes:
Kevin
schnitz 11-15-2007 06:32 AM
Kevin
Kevin, they just use lead in China. No steel. I can weld, but I'm often asked not to. I shouldn't say it isn't pretty, but it looks as bad as two 17 year old inbred first cousins french kissing at a church social. Trust me, it's [/I]that[I] bad....
Twisted, I'd give the entire left half of my body to have your skills and talent. Keep it up.
In a while, Chet.
powerrodsmike 11-15-2007 09:02 AM
In a while, Chet.
Those long cold winters must create some very interesting events.
I don't want to know how you know what that particular activity looks like. :D
Steel tables are best. Always flat, (unless you weld stuff to them) don't burn, easy to clean, stronger than dirt.
Having the top longer than the frame underneath is a good way to build a fab table, as it allows you to clamp stuff together easier at the edge.
I think I'd take the grinder to that one corner that is opposite the door. That looks like it could be painful if you bump it when you are walking by.
One of my tables in the shop is a 4'X8' 3/8" plate, about 36" tall, with a 6" overhanging edge. . That thing would get some of my skin almost daily until I filed it's teeth.
Later, mikey
Henry Highrise 11-15-2007 11:15 AM
I think the brownies are really doing a job on Chet! :D Sheeeesh!
Twisted Minis 11-15-2007 12:07 PM
Funny you mention that, I did just that last night while I was polishing some welding berries off the top. I didn't like the idea of walking into it.
