Steel Workbench - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2007, 12:48 AM
Twisted Minis's Avatar
A different breed
Last journal entry: New Truck
Steel Workbench
Always wanted a welding table, or steel workbench. Getting a new (read used) toolbox freed up a lot of space and I decided to build one.
It needed adjusters since half of it sits on a mat.
I also at the same time built a small cart for my new plasma cutter. I got tired of dragging it across the ground with a tangle of wires.
And here it is complete, with my plasma and my new Milwaukee HD Chop Saw tucked underneath.
Nice and neat.
And heres some parts for my current project.
Old 11-14-2007, 09:17 AM
dinger's Avatar
Nice work, TM. Of course by now, I wouldn't expect anything less. It looks heavy duty enough to do anything needed. Dan
Old 11-14-2007, 07:46 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
How thick is the top? Got anything you might do different?
In a while, Chet.
Old 11-14-2007, 08:34 PM
A different breed
The top is 3/16" that I got off the remnants rack at the local steel yard.
So far after using it I wouldn't change anything, but I know I will be adding a simple touch to it soon.
Old 11-15-2007, 03:09 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
With all the steel you weld daily, the Chinese will have a shortage. Great table. Thanks for sharing the info. Now all I gotta do is learn to weld
Kevin
Old 11-15-2007, 06:32 AM
schnitz's Avatar
Wiki Edits: 54
Kevin
Kevin, they just use lead in China. No steel. I can weld, but I'm often asked not to. I shouldn't say it isn't pretty, but it looks as bad as two 17 year old inbred first cousins french kissing at a church social. Trust me, it's [/I]that[I] bad....
Twisted, I'd give the entire left half of my body to have your skills and talent. Keep it up.
In a while, Chet.
Old 11-15-2007, 09:02 AM
powerrodsmike's Avatar
Wiki Edits: 161
In a while, Chet.
Those long cold winters must create some very interesting events.
I don't want to know how you know what that particular activity looks like.
Steel tables are best. Always flat, (unless you weld stuff to them) don't burn, easy to clean, stronger than dirt.
Having the top longer than the frame underneath is a good way to build a fab table, as it allows you to clamp stuff together easier at the edge.
I think I'd take the grinder to that one corner that is opposite the door. That looks like it could be painful if you bump it when you are walking by.
One of my tables in the shop is a 4'X8' 3/8" plate, about 36" tall, with a 6" overhanging edge. . That thing would get some of my skin almost daily until I filed it's teeth.
Later, mikey
BE different....ACT normal.
Old 11-15-2007, 11:15 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I think the brownies are really doing a job on Chet! Sheeeesh!
Old 11-15-2007, 12:07 PM
A different breed
Funny you mention that, I did just that last night while I was polishing some welding berries off the top. I didn't like the idea of walking into it.
Welding Stainless Steel to Hot Rolled Steel? Rambo_The_Dog General Rodding Tech 11 05-07-2007 11:05 AM
Cowl Hood - Fiberglass vs Steel leejoy Body - Exterior 3 06-14-2006 10:20 PM
DIY - custom steel cowls, for a steel hood? Woogeroo Body - Exterior 1 12-18-2005 08:43 PM
Is if me or the steel? redsdad Body - Exterior 4 09-10-2005 09:21 PM
Best Rust Inhibitor? bigbrowndog Body - Exterior 45 11-21-2004 09:26 PM
