Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Steel Workbench
Thread: Steel Workbench
Old 11-15-2007, 09:02 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
Originally Posted by schnitz
I shouldn't say it isn't pretty, but it looks as bad as two 17 year old inbred first cousins french kissing at a church social. Trust me, it's [/I]that[I] bad....
In a while, Chet.
Those long cold winters must create some very interesting events.
I don't want to know how you know what that particular activity looks like.
Steel tables are best. Always flat, (unless you weld stuff to them) don't burn, easy to clean, stronger than dirt.
Having the top longer than the frame underneath is a good way to build a fab table, as it allows you to clamp stuff together easier at the edge.
I think I'd take the grinder to that one corner that is opposite the door. That looks like it could be painful if you bump it when you are walking by.
One of my tables in the shop is a 4'X8' 3/8" plate, about 36" tall, with a 6" overhanging edge. . That thing would get some of my skin almost daily until I filed it's teeth.
Later, mikey
BE different....ACT normal.
