-   -   steering (http://www.hotrodders.com/forum/steering-201802.html)
bgraham 07-10-2011 07:30 PM
steering
what would be a good manual steering box for a 1946 ford sedan with a 302 engine and stock front end. thanks
35terraplane 07-11-2011 01:41 PM
Steering
I have a 46 ford coupe with a sbc in it and a R and P steering. With that said if you are going to use a manual steering and a stock front end, Then IMHO you will have to use the stock or same size as stock steering wheel. They are very hard to turn at slow speeds, very hard. I have a smaller than stock wheel on mine with manual steering and it is a b---h to turn at a stop or going very slow. I didn't build the car and I have not changed it yet. I did have a 40 2dr with cross steer and put power on it and it was too much as you could hardly touch the wheel.
Bob
aosborn 07-11-2011 10:33 PM
A Vega steering gear is very good and are readily available for a reasonable cost.
Andy
