steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2006, 12:06 PM
steering
i just need help with my steering in my truck, i put headers on my small block in my 82 s10 and now my steering doesnt work. i ve been drivin my truck for about 5 years now.
Old 05-03-2006, 12:37 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
We need more information than that...do you think it is a heat related problem? Or is it a interferance problem? Did this happen immediately after you put the headers on?
Old 05-05-2006, 07:47 AM
37 plymouth coupe's Avatar
re: steering
as henry said, need more info...I am in Mesa AZ..if you ever get up this way, i'll take a look at it for you.
Old 05-05-2006, 09:11 AM
steering
no its not a heat problem, is a clearance problem. with the headers on my steering rod hits the header and i cant get it to line up its about a 4 inch differance. is there a special adapter that i have to use?
Old 05-05-2006, 09:36 AM
Lost in the 60's
Wiki Edits: 4
Its called a 'U-Joint" You can get them from Borgeson Universal Company. www.Borgeson.com You may also need a short piece of shaft and possibly a support bearing and bracket. Take a look at what they have, you can get everything you need to re-position your steering shaft around your headers.
Old 05-05-2006, 10:35 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
steering
You probably have the wrong headers for your truck. If you do a google search for "V8 headers S10" you will find the ones that are built for this conversion.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 05-05-2006, 11:26 AM
steering
thats the thing those are the headers for the s10 conversion, and every thing works with no problems.
Old 05-05-2006, 11:30 AM
home brew's Avatar
steering
If " very thing works with no problems" then you don't have a problem.
Old 05-05-2006, 12:06 PM
Lost in the 60's
Wiki Edits: 4
Now I am really confused! Sheeeeesh! First you have a problem...now you don't have one.
Old 05-08-2006, 10:20 AM
steering
no he just misunderstood me everything else works but the steering shaft. but i am checking on the u-joints. i checked out there web site and i think it might work with what they carry, but not sure yet. is there anyone else who has done a s10 coversion?
Old 05-08-2006, 11:36 AM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Its it possible you have the wrong engine mounts and your engine is siting to low? Did you get the bolt on s-10 v8 mounts?
Old 05-08-2006, 12:09 PM
steering
yes, i got every thing for the s10 conversion headers, raditor, starter, motor mounts, and other misc. items
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
power steering Paco Suspension - Brakes - Steering 9 10-31-2006 06:02 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Problem: Steering Rack? horvath Suspension - Brakes - Steering 64 06-15-2005 08:11 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
