steering bell joint = U joint ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2009, 12:29 PM
user151's Avatar
I have a Chevy bell joint, with the DD slip shaft to a rag joint (see pix). The bell joint splined end will attach to my steering shaft, and I can attach the end of the slip joint to the steering box (after removing the rag joint connector).
So I would be using the bell joint as a U joint. Any problems with this application?
(If it is not appropriate I'll just but a U joint from Speedway.)
ID:	38204   Click image for larger version
Old 05-17-2009, 12:35 PM
powerrodsmike's Avatar
Wiki Edits: 161
Buy the u joint, or use a rag joint to couple the dd end to your steering box. It needs the flexibility.
later, mikey
BE different....ACT normal.
Old 05-17-2009, 12:55 PM
user151's Avatar
ok on rag joint...
Adding the rag joint is no problem... but can I use the bell joint like - or at the same angles as - a U joint?
Old 05-17-2009, 01:10 PM
Wiki Edits: 161
I'm not sure you can run one at the 30 plus degrees that a u joint will run at, usually those bell joints are set up at fairly low angles.
I would think that you could push the bell and shaft together all the way, and see where it binds, then run it at a lesser angle than where it binds and you should be ok. I'd be concerned with the teflon balls falling out of the slots at high angles.
I never tried to use one in a high angle, what will your operating angle be?
Later, mikey
Old 05-17-2009, 04:19 PM
user151's Avatar
operating angle
I think you are right about low angle from what I have seen on the Chevys in the local junk yard here... I haven't set it up yet but if it's a significant angle I'll go with a real U joint.
Old 04-23-2011, 11:53 AM
Dale
I go to the junk yards and grab a hand full of intermediate steering shafts from front wheel drive cars. These will come with 1 or 2 U-Joints in them and some have rag joints and double D slip joints on them. These come in very handy when connecting steering columns. I have even split the the 2 halves and mixed and matched the pieces.
I have a Model A Pickup to build, have Lots of questions. 88lowrider General Rodding Tech 103 05-14-2009 09:46 AM
Joke about Christmas carols ChevelleSS_LS6 Hotrodders' Lounge 1 12-09-2004 12:01 PM
Steering box/Coupler (rag joint) Questions RObs71Nova Suspension - Brakes - Steering 1 10-26-2004 11:34 PM
Replace Steering U joint Dave E Shank Suspension - Brakes - Steering 1 08-13-2004 05:51 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
