Steering Box - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2008, 10:19 PM
Steering Box
i have a 1951 ford pick up & the steering has a lot of play in it.
how do i adjust the steering box? bob5740@verizon.net
Old 04-12-2008, 11:24 PM
redlightning's Avatar
The way my Dad taught me on my 54 was: Loosen the lock nut, and while someone is gently working the play back and forth,slowly turn the adjuster in till it is seated.And re tighten the lock nut.
Old 04-13-2008, 01:06 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
On some of the '60's and '70's boxes, GM in particular, there is a 'high' spot so to speak, you can feel when the worm gear is centered, you would want to make the adjustment there, and only lightly seated, you could damage the roller balls otherwise. Repair manuals should have the procedure for your car.
Semper Fi
Old 04-13-2008, 09:59 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I always turn the wheels either to the left or right when I make the adjustment...because the worm has more wear in the center...this way you will not get it too tight. Loosen the jam nut and turn the adjuster in untill you feel it make contact then back of just a little and tighten your jam nut while holding the adjuster.
Old 04-14-2008, 01:35 AM
powerrodsmike's Avatar
Wiki Edits: 161
I have an original factory manual for 49-51 ford trucks.
I scanned the page you want.
Here is a link to the page with a bigger scanned image.
http://www.hotrodders.com/gallery/sh...cat/500/page/1
Just click on the picture and it should get bigger.
Hope this helps,
Mikey
BE different....ACT normal.
Lowering my steering box LiftFlat Suspension - Brakes - Steering 1 07-07-2007 01:49 AM
power steering box conversion - w/o fluid? stratt134 Suspension - Brakes - Steering 3 07-27-2006 06:16 PM
vega steering box stiff to rotate pcoghlan Suspension - Brakes - Steering 2 05-28-2006 09:20 AM
Problem: Steering Rack? horvath Suspension - Brakes - Steering 64 06-15-2005 09:11 PM
Steering box question Ratoflic Suspension - Brakes - Steering 1 04-27-2005 04:14 AM
