steering box - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2008, 07:58 PM
powered by 1.21 gigawatts
steering box
anyone know what i can replace a power box with a manual steering box in 73 monte carlo
Old 07-16-2008, 08:35 PM
Most '68-up GM non-full-sized cars (except Corvette, Corvair, and Vega) use manual steering gears that will fit your car. Truck gears mount to the outside of the frame, so they won't work.
You will also need a manual-steering pitman arm, since the shaft hole is not the same size as yours. You'll likely need the coupler that hooks the gear to the column, so grab the one that's on the gear you're going to use.
Your shoulders will curse you at first, but they'll either adapt or die.
Old 07-16-2008, 08:43 PM
i only plan to go straight!!!!!!!!!!
when you say non full sized some examples are?
Old 07-16-2008, 08:47 PM
here is another question do i need to get rid of the power box? or can i just use it without the pump etc?
Old 07-16-2008, 09:13 PM
Chevelle, Nova, Cutlass, LeMans, Camaro, Firebird, ... should I go on?
Old 07-19-2008, 02:17 AM
That's the ones. Nova, Camaro, Chevelle, or any other division's cars that are made from them (clones).
A non-powered power box is harder to steer than a manual box, but a friend of mine drove a '75 truck like that for a couple of years.
Lowering my steering box LiftFlat Suspension - Brakes - Steering 1 07-07-2007 01:49 AM
power steering box conversion - w/o fluid? stratt134 Suspension - Brakes - Steering 3 07-27-2006 06:16 PM
vega steering box stiff to rotate pcoghlan Suspension - Brakes - Steering 2 05-28-2006 09:20 AM
Problem: Steering Rack? horvath Suspension - Brakes - Steering 64 06-15-2005 09:11 PM
Steering box question Ratoflic Suspension - Brakes - Steering 1 04-27-2005 04:14 AM
