steering box blew its seals....78 nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2005, 07:56 AM
snod83's Avatar
Alright, as the title says, I have a 78 nova that just blew all the seals on the steering box. I think its because I used a remote resevoir pump from a lates 70s early 80s conversion van on it.... I got the pump and resevoir from a junkyard for cheap. I think that since the van is heavy it must put out alot more pressure than the nova box is good for. Am I right in thinking this? The wierd thing is that the pump/box combo worked great for a year!!! And then suddenly lost everything! Its crazy....
And a side question. Is it hard to replace the seals in a steering box? I have only torn apart a corvair box on my t-bucket and there was nothing to it, but I think this nova box may be a bit more complicated.
Thanks for your time and input,
Ryan
Old 10-31-2005, 07:05 PM
Another good used box with less miles is my solution...
DEUCE.....
Old 10-31-2005, 07:19 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
DEUCE.....
Yup..probably just wore out the old one..
OMT
Old 11-01-2005, 05:54 AM
snod83's Avatar
The car only has 40,000 miles on it!! I don't really think it wore out because it was not a gradual thing. It dumped all the fluid out in a matter of 30 seconds and it had never had a leak before then! I am confused.
Old 11-01-2005, 06:33 AM
poncho62's Avatar
Wiki Edits: 5
Probably the bottom sral (pitman arm).........you can buy a seal kit for it. It's a double seal. It's a bit of a pain, but not bad.
Old 11-01-2005, 06:49 AM
Jake_Dragon's Avatar
Last journal entry: New Carb
Originally Posted by poncho62
Probably the bottom seal (pitman arm).........you can buy a seal kit for it. It's a double seal. It's a bit of a pain, but not bad.
I was thinking the same thing, had a similar problem where the arm actually had a groove in it and I ended up getting a different one anyway.
Old 11-01-2005, 07:50 AM
snod83's Avatar
You are right about it leaking from the pitman arm seal but I also think it is leaking from the input shaft seal too. Is this hard to change?
Do different powersteering pumps put out different pressures, or are all the pumps the same?
Thanks for your help so far!
Ryan
Old 11-02-2005, 12:52 AM
Pull the pitman arm off and the snap ring that holdes the seal in. Then start the car and turn the wheel. It will blow the seal out (and make a mess so shut it off quick). Then you just have to put the new seals (and washer and snap ring) in and you are good to go. Less money and less work then a junkyard box that might still leak.
Edit: turning the wheel one way will blow it out and one won't. I don't remember which is which. Post up when you figure it out.
Repair a leaky steering box gator412 Suspension - Brakes - Steering 8 06-01-2008 03:03 AM
Will power steering box from 82 camaro work in 67 el camino dave2148 Suspension - Brakes - Steering 7 09-05-2005 09:37 PM
gm 525 steering box clarence latshaw Introduce Yourself 1 07-17-2005 08:47 PM
1966 Chevy full-size Steering box interchange Parisienne66 Suspension - Brakes - Steering 1 03-01-2004 01:49 PM
Manual Steering Box sb72elcamino350 Suspension - Brakes - Steering 1 01-29-2004 11:07 AM
