Steering box clearance issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2014, 09:35 PM
tools's Avatar
Hi
I have a 41 ford coupe with a 70's camaro stub welded in ( by previous owner ) with a 350/ turbo 350 . My problem is that the power steering gear box needs to be moved back or lower by about 2 inches to make room for the radiator. I can't mount the radiator any higher to get around this. Is there a smaller power steering unit I can use ? What problems will I create by moving the steering box. Any ideas on how to get around this will be appreciated.
Thanks
Joe
Old 01-18-2014, 09:56 PM
Last journal entry: New Rev wheels and BFG KDW II tires
I suggest you modify the radiator to fit the car. Moving the box is going to mess up the steering geometry. You could possibly tilt it some without affecting it a great deal but moving it 2" isn't going to work.
They do have rack and pinion kits but they are relatively expensive unless you can modify a stock rack to fit your car. Reworking the radiator I think is your best bet or moving it away from the box.
Aftermarket oil pump pickup clearance issue ssparko Engine 8 01-23-2012 08:32 PM
Steering Box Clearance Problems 54 Chevy P/u w/Camaro Clip mboyle Suspension - Brakes - Steering 20 12-13-2010 10:24 PM
steering gear box 55 chevy(manual box) 55 Bullit Suspension - Brakes - Steering 3 11-21-2010 02:35 PM
header clearance issue with AC Brackets BuddyJarvie Engine 4 09-08-2007 12:15 AM
Clearance issue... staleg General Rodding Tech 6 04-25-2007 06:15 AM
