IIRC, big-block Novas were available with power steering from the factory. You may run into steering gear clearance problems if you are using small-block motor mount frame brackets. Big-block frame brackets move the engine a little to the right.
BB cars also used a trans crossmember with the mount holes offset to the right. All T400 crossmembers are offset, as are the BB stick crossmembers, but I hear the standard manual/T350/PG crossmember can have the holes elongated so everything will line up if you're not using a T400.
The steering couplers are different, I believe because the steering gear input shafts are of different diameter.
You may need to check your heater box clearance also. BB Novas used a different heater box & core.
The fan shrouds may also be different due to the engine offset, but I don't know for sure.
