Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Steering box help!
Old 02-20-2010, 11:09 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
It's not that hard. The hard part is removing the Pitman Arm from a Steering box.
If you're swapping from a Manual box to a Power Steering box you need the Pitman Arm that was on the Power box. Pitman Arm for Manual Box doesn't work on the Power box.
You need a Tie Rod seperator tool or other to remove the Pitman from the Draglink.
