Steering box help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2010, 12:01 AM
Madmax305's Avatar
Steering box help!
Can anybody explain how to change a gear box with power steering in a 1967 el camino? Is it that difficult?
Old 02-21-2010, 12:09 AM
SSedan64's Avatar
It's not that hard. The hard part is removing the Pitman Arm from a Steering box.
If you're swapping from a Manual box to a Power Steering box you need the Pitman Arm that was on the Power box. Pitman Arm for Manual Box doesn't work on the Power box.
You need a Tie Rod seperator tool or other to remove the Pitman from the Draglink.
Old 02-21-2010, 12:17 AM
Madmax305's Avatar
It's a power steering box to a power steering box. So I need a tie rod seperator tool, anything else that I should know, remember I'm a noob!
Old 02-21-2010, 12:36 AM
SSedan64's Avatar
(May) need some Flare Fitting wrenches for the hose connections. They can be tight and round off the Hex nuts if using a regular Open End wrench.
The Pitman Arm will be very hard to remove, I recommend spraying the splines and threads with WD40 or similar several times & a day ahead of time. May require some heat from a torch while applying pressure with the Pitman tool.
Flare Nut Wrenches-- These are Metric, you need Standard type.
http://www.harborfreight.com/cpi/cta...emnumber=99993
Ball Joint/Tie Rod Seperator tool
http://www.harborfreight.com/cpi/cta...emnumber=38649
Pitman Arm Tool
http://www.harborfreight.com/cpi/cta...temnumber=1752
These tools can be found at AutoZone, Advance etc.. they have loaner tools that you can use without having to buy them.
Have to unbolt the Rag joint from the Steering Column also but, that's easy.
Old 02-21-2010, 12:46 AM
SSedan64's Avatar
Would be a good idea to flush the system before installing the new Box also.
http://cardone.com/english/club/Prod...%2020-0012.pdf
Old 02-21-2010, 01:37 AM
SSedan64's Avatar
Are you going with the Stock Power Steering 3-3/4 to 4-1/4 turn Box or the Close ratio 2-1/2 to 3 turn, lock to lock Box?
I noticed Rock Auto.com has the 2-1/2 turn box for $117 w/$75 core charge.
http://www.rockauto.com/catalog/raframecatalog.php
Old 02-21-2010, 09:30 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
They also make a pitment arm puller. http://www.sears.com/shc/s/p_10153_1...5x000001&aff=Y .
Cole
Old 02-21-2010, 10:01 AM
Madmax305's Avatar
I'm going with the 2-1/2 to 3 turn. I bought it from napa auto, it was about $175. Thanks for the advice on the tools. Quick question, once I get the pitman arm off, how do I re-install it, can it be tapped on with a hammer, or does it have to be pressed on?
Old 02-21-2010, 10:06 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
With clean splines properly aligned, all it takes is torquing the nut correctly to secure the pittman arm- the splines are tapered.
Old 02-21-2010, 10:44 AM
Madmax305's Avatar
Any idea on what the torque would be? Thanks for the help....
Old 02-21-2010, 11:21 AM
eloc431962's Avatar
Wiki Edits: 37
It don't press on just Slip it on and it should toqure at-least 180 lbs.
Cole
Old 02-21-2010, 11:23 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the nut's 1-5/16" the torque is 180 ft/lb. I've always run them down w/an impact wrench- but I do not suggest you do the same.
Old 02-21-2010, 01:33 PM
Madmax305's Avatar
Wow, ok thanks guys, I would of never guessed it would have been 180ft lbs.
Old 02-21-2010, 04:23 PM
T-bucket23's Avatar
Wiki Edits: 26
For a vehicle that old you may want to make sure someone has a rag joint. They are know to fall apart when you try to unbolt them
Chet
Old 02-21-2010, 04:55 PM
Madmax305's Avatar
Thanks for the heads up, I already bought one...
Lowering my steering box LiftFlat Suspension - Brakes - Steering 1 07-07-2007 01:49 AM
power steering box conversion - w/o fluid? stratt134 Suspension - Brakes - Steering 3 07-27-2006 06:16 PM
vega steering box stiff to rotate pcoghlan Suspension - Brakes - Steering 2 05-28-2006 09:20 AM
Steering box question Ratoflic Suspension - Brakes - Steering 1 04-27-2005 04:14 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
