Steering box for model a - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2013, 11:53 AM
NoobRodder's Avatar
Last journal entry: Cragars
There are many steering boxes that are very close in size to the vega steering box I am thinking on using an chevy pu box in my model a that is almost the same size except the output shaft is longer. Anyone see and down sides to using that box ?
Old 04-09-2013, 07:55 AM
454 Rattler's Avatar
NEVER SATISFIED !!
If you've got it, then give it a try. That's what Hot Rods are all about.
I tried a 525, a Vega and a Unisteer. The Unisteer was the best in my opinion.
454 RATTLER
Old 04-09-2013, 07:11 PM
Depending on your set up it may be better as you will not need the Vega drop Pittman arm. Make sure the rotation is right for your set up. Nothing worse than hooking up a cross steering setup to find it does not turn the right direction.
steering gear box 55 chevy(manual box) 55 Bullit Suspension - Brakes - Steering 3 11-21-2010 01:35 PM
vega steering box on a 1930 model a frame David G Suspension - Brakes - Steering 2 01-22-2006 08:14 PM
Late model GM Steering Column for Model A Woody31coupe Suspension - Brakes - Steering 3 12-31-2005 05:55 AM
Loose steering even though steering box is relatively new? 72Nova Suspension - Brakes - Steering 8 05-14-2003 03:09 PM
model a/vega steering box jvarble Suspension - Brakes - Steering 5 01-11-2002 07:41 AM
