Thanks Joe,
I don't think he gave any thought to this at all, and he's the type of kid (aren't they all) that figures if it looks right it is right. I'll go over this weekend and check it out. I'm pretty sure he'll have chucked the old steering by now, so not sure what to look for. |
Unfortunately, there are a million wrong ways to do this and only one right way. |
Pull the spring out and put the suspension back together. Put the car up on jack stands, a tire on, a jack under the lower control arm, and a piece of ply-wood leaning against the tire. If when you raise or lower the tire it creates a gap (front or back) between the sidewall of the tire and the ply-wood (don't let the bottom move) you have bump steer. I wouldn't worry too much about the Ackerman as that is mostly built into the steering knuckle. Just make sure when looking from above that the rack and pinion is mostly in line with the tie-rods.
One answer would be "less than it had before". It seems that it is too late for that one to work however. Another choice could be less than the toe spec (if the spec is 1/16" toe-in per tire than I think less than 1/16" would be a good bet). The last choice could be "as little as you can get" because with a swap like this that might be all you could hope for.
Here is another thread on the topic. Bumpsteer limits |
| Very Simple Power Rack and Pinion Steering Question | djjc76 | Suspension - Brakes - Steering | 1 | 01-25-2008 12:43 PM |
| Rack & Pinion Steering | Rick Dolinar | Suspension - Brakes - Steering | 2 | 07-02-2007 06:19 AM |
| Triumph tr-3 worm box swap with rack and pinion | lugog | Suspension - Brakes - Steering | 1 | 06-29-2007 03:12 PM |
| Rack & Pinion Steering on a Chevy C-20 Suspension? | Dusty82 | Suspension - Brakes - Steering | 3 | 03-01-2005 09:15 AM |
| power steering rack and pinion swap | Paco | Suspension - Brakes - Steering | 0 | 04-03-2002 06:56 PM |
