steering box rebuild help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2006, 11:48 PM
gator412's Avatar
1955 2nd series Chevy Pick Up
Last journal entry: Body work and U bolts
I did a search and looked around but didn't find anything so......I have a 1975 Chevy truck power steering box that leaks from where the steering shaft connects. The auto parts stores want about $180 for a rebuilt one. But a rebuild kit is $49. So can any of you give me advice on how to rebuild the box. I do not know the type of box it is but the #s on it are 7802644. On the adjustment screw plate there is #304 in small print.(could be 804). Hope this helps you to help me!
Thanks!!
Old 02-01-2006, 06:18 AM
Hmmm see if this helps you a bit....
Hey Gator,
I had this issue with my 69 Beaumont (Canadian Sister car to Chevelle) I have a foctory chassis manual that tells you how to do it. And I also found a few articles in street rod and performance magazines. I too was faces with spending $145 plus core charge to get a new box. So here is an article to get you started. Also see if you can find a chassis repair manual for the truck, it will help you out. The work is not hard... Here is a link to one of the articles I referenced when rebuilding my power steering unit.
http://off-roadweb.com/tech/0501or_steer/
Hopefully this helps you out a bit.
Jesse
Old 02-01-2006, 09:08 AM
gator412's Avatar
Thanks Jesse! Here are a couple bad photos of the box. By the way this steering box is in my 1955 1st series chevy truck. I added power steering to it and am trying to get everything completed now. (The steering box is out of a 75 chevy truck.)
Name:	Steering pump 1.JPG
ID:	9755   Click image for larger version
Name:	steering pump 2.JPG
Old 02-02-2006, 08:47 AM
gator412's Avatar
So is there anyone else out there who has a more detailed explaination of the disassembly of the steering box? It would be nice to know more as I get ready to rebuild the box.......anyone
Old 02-03-2006, 02:49 PM
gator412's Avatar
thanks for the help guys, I have rebuilt my box. I found some more info and help on the stovebolt site.
Old 02-03-2006, 03:10 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Glad to hear you got it good to go!
Old 02-06-2006, 12:27 AM
Where did you find the info?
Old 02-06-2006, 11:52 AM
gator412's Avatar
I posted the info on stovebolt.com forums. Here is a link to the question and answers.
http://www.stovebolt.com/bboard/cgi-...c;f=2;t=010811
By the way Jim I grew near Houma La. But now live in CA.
Old 02-09-2006, 12:07 AM
Different, ain't it?
Thanks for the info.
rebuilding steering box? 60 chevy Suspension - Brakes - Steering 1 01-04-2006 08:29 PM
steering box blew its seals....78 nova snod83 Suspension - Brakes - Steering 7 11-01-2005 11:52 PM
Vega Steering Box Frisco Suspension - Brakes - Steering 2 09-29-2005 08:14 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
Steering Box Rebuild? project69ss Suspension - Brakes - Steering 1 01-23-2003 10:32 AM
