Steering box removal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2006, 12:15 PM
Hey guys,
I have a 67 mustang coupe 289. I am in the process of rebuilding the suspension and steering and have removed all steering linkage but the box nad pitman arm. I would like to clean and paint the box, as well replace column seals. However, I would prefer not to go through the hassle of removing the steering column.
So, my question, can I remove the box w/o removing the steering column. If so, do I just remove the mounting bolts on the frame or is the column somehow locked on to the box.
Thanks for your help!
Old 12-08-2006, 08:25 AM
YES or NO.
If your car has the 2-piece steering shaft, evidenced by the presence of a "rag"-joint between the box and column near the frame, then yes!
If the column tube seats on the steering box, then no, UNLESS you can raise the car enough to slide the box down and withrdraw the steering shaft from the column from below. Neither likely nor really sensible.
Old 12-08-2006, 09:03 AM
Thanks. Well I don't have the rag joint, so I guess that kills that idea. How do I go about removing the steering column?
Old 12-08-2006, 06:45 PM
It is a royal pain in the butt unless you are a rubber jointed 125 # guy. If you are a wide body, then you may consider removing the seat. You must remove the steering wheel and then start unbolting the column at the dash. If my memory serves me, you also have to unbolt the clutch/brake bracket from the firewall as well as remove the master cylinder. If you have 3 on the tree, you will have to disconnect the linkage at the column. I think you can unplug the wiring harness near where it enters the column. If not, you will have to disconnect the turn signal wires and horn wire and pull out of the column. Now you remove the rubber insulator where the column goes thru the firewall. At this point you still have your sanity, unbolt the box from the frame and pull out at the bottom.
Good luck!!!
Trees
power steering box conversion - w/o fluid? stratt134 Suspension - Brakes - Steering 3 07-27-2006 05:16 PM
steering box blew its seals....78 nova snod83 Suspension - Brakes - Steering 7 11-01-2005 11:52 PM
1952 Chevy car power steering box what will work? Michael Bryan Suspension - Brakes - Steering 3 04-17-2004 10:15 AM
Power Brakes for 52 chev car Looking for a steering box that will work Michael Bryan Suspension - Brakes - Steering 0 03-29-2004 07:22 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
