Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Steering change-out
Old 08-14-2008, 10:10 AM
Brimstone Brimstone is offline
Depending on how new of a steering column you go with (or how different), you might have to worry about doing some re-wiring. If your wiper switch is in the dash and/or the dimmer switch is on the floor, then you might have to do some wiring work if the replacement column has 'em on the column stalk instead.
You might have already taken this into account, but it's something else to think about.
