steering colum? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2010, 09:20 PM
Last journal entry: Motor build up 2
steering colum?
Hey guys i have a 1949 ford f-1 pick up with stock steering straight axle. My question is if i wanted to use a steering colum out of a new vehicle with a shifter on the colum what should i be looking for? How can i hook it up do i need an addapter or will it fit together with no problems?
Old 04-08-2010, 09:32 PM
Wiki Edits: 27
steering col
I think you have a solid shaft from the steering gear to the steering wheel, When you change the column you will have to get or fab a new mount to the inst panel and floor. IF you don't use a tilt you MIGHT be able pull the shaft out of the new column and slide it over the shaft. If not they make couplers, speedway has a variety of sizes if you have to use the complete columh.
Old 04-08-2010, 09:38 PM
cool. can i use a colum off any car or truck?
Old 04-08-2010, 10:15 PM
Wiki Edits: 27
column.
Most us full size cars and trucks use 3/4 inch shafts, the spline for the steering wheels are different from differend manufacturers but they sell wheel adaptors alot of adaptors won't switch the turn signal off after you turn.
Old 04-10-2010, 12:05 AM
fast68's Avatar
likes chevy trucks & boobies
the old 70s and 80s RWD car and '70s and '80s truck columns commonly are used in these trucks and hot rods
work pretty easily
can shorten them as well, they collapse, under the hood part,
1987 steering colum Big Rob Electrical 1 09-09-2009 12:41 PM
Chevy steering colum in a Ford daybreaker69 Electrical 6 03-14-2009 04:08 PM
steering colum tsw27 Engine 1 12-13-2004 01:15 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
Need a steering colum for my 89 camaro KentuckyCamaro Interior 2 11-10-2002 04:11 AM
