Originally Posted by 40chevy
See thats why I asked..... I never thought about no key. The rear end I will use is out of a 99 camaro not the Caprice.
The width on the Camaro rear axle .....is it compatible with the 40 ?? Wide enough or too wide. I have never built a 40 Chevrolet so I do not know what width you would need. I would measure the width of the stock rear end and try to match it fairly close......
Measure the 40 rear end this way.....
and the Camaro the same way...
I would most likely try to get a master cylinder with the same bore as the Camaro.....
Here is a photo of a Chevy/GMC van tilt column.....
