steering column - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2009, 08:18 PM
steering column
i would like to what orther chevy car year steering column would fit in my 56 chevy i hope someone out there could help yhanks junior
Old 06-19-2009, 05:13 PM
fast68's Avatar
likes chevy trucks & boobies
only another 56 chevy one and whatever other years are the same design will fit, mid 50s years
otherwise modifications will be necessary if its from anything else
pretty basic easy here
good luck
Old 06-29-2009, 06:03 AM
steering
i would like to if a 64 chevy steering cloumn would fit in my 56 chevy
Old 06-29-2009, 08:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Keep your '56 column and bolt a '64 Impala steering wheel onto it.
Old 06-29-2009, 08:30 AM
steering
ts go on cobalt327 i have a 3 speed coulmn and i need auto. cloumn. junior
Old 06-29-2009, 08:38 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
In that case, take the stick sleeve off, install an AT one in it's place.
Don't have a sleeve for an AT, you say? Fine. Grind the shifter lug off, do a little "body work" on it, repaint and reinstall.
What I'm getting at here, is you do not need to change out the whole column (along w/the wiring, etc.) in order to get to where you wanna go.
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
Steering Column (shaft) collapsed scr8pin_f100 Suspension - Brakes - Steering 8 02-28-2009 11:18 AM
Chevy AD truck steering column question mr52pickup Suspension - Brakes - Steering 1 10-24-2008 06:45 PM
Steering column switch 82 Dodge 150 Bryan59EC Electrical 6 07-05-2008 08:07 AM
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 11:36 AM
