someone that owned my dad's '72 had the same problem. they put on a small Momo steering wheel, it's ugly, but it's small and works. my dad's not that small ither. nice looking wheels are sold in the same size as the momo's.
use a van column through 1979, lots were tilt, all you have to do is collapse the engine ay end of the column inside itself a few inches and it will bolt right in same column as the 71 72 trucks
do a google for van tilt column 67-72 truck lots of ppl have done it ![]() good luck |
As suggested, you can use the van column but on my '72 C-20 I took the column out and cut the coupler shaft and welded it back together. To insure good strength, I first butt welded the two pieces back together then positioned a piece of steel tubing over the butt weld and welded both ends of the tubing to the shafts. It actually looks stock and I have had no problems. Doing this allowed me to position the steering wheel further away from the seat.
Do not try this unless you are an experienced welder, preferably with a Tig welder. If you do not have the experience or equipment, a good welding shop should be able to do the job for you for a few bucks. |
I have taken that style column apart and collapsed the tubes and the shaft an equal amount to shorten them. It isn't that hard to do but you would probably end up with a column that wouldn't collapse if you were in a wreck.
It may be safer than cutting and welding on the bottom end. A couple of small tack welds would hold each component in place after they were shortened and then you could reassemble it. |
Thanks for the tip |
Yep makes it like every Pre 69 car out there with a very few exceptions.
That is why I recomended a couple of very light tac welds, just enough to keep it from slipping but not enough to hold on impact. plastic pins would be better. |
| power steering for 1953 chevrolet car | Jeffs50ford | Suspension - Brakes - Steering | 4 | 02-19-2007 10:55 PM |
| Question on 66 Mercury Comet steering and brake issues....... | onebadmerc | Suspension - Brakes - Steering | 5 | 01-11-2007 05:41 PM |
| Problem: Steering Rack? | horvath | Suspension - Brakes - Steering | 64 | 06-15-2005 08:11 PM |
| Hotrodders Knowledge Cluster: Power Steering Conversions | Jon | Suspension - Brakes - Steering | 0 | 09-03-2003 11:20 PM |
| Whatever happend to these guys? | hot_rod_kid | Hotrodders' Lounge | 20 | 12-17-2002 09:20 AM |
