Steering Column - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2012, 09:47 AM
1965 mustang project
Last journal entry: what are these from??
Steering Column
So purchased a manual to power steering conversion kit. the direction's say to "take note of the measurement the end of the column shaft to the column bell. this must be maintained with the replacement column shaft " WELL my steering column was out of the car before i had ordered the conversion kit. i've already cut 5 1/2 inches off it... im close, but don't want to go too far.. is there some was to get a measurement or something more sure than my guessing at it ??
Old 01-26-2012, 10:00 AM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
I am not sure I understand what you are asking about?
Old 01-26-2012, 10:45 AM
my steering column has to be cut shorter tfor the new power steering shaft to fit... im guessing at the shortening, and was wondering if there is a right way to measure and cut ??
Old 01-26-2012, 05:41 PM
Make and model of car would help
Old 01-27-2012, 07:16 AM
1965 mustang coop
Old 02-04-2012, 10:56 PM
Buy some 3/4" wood dowel from your local hardware store. Use that as a mock up for your steering shaft length.
steering column junior56chevy Suspension - Brakes - Steering 5 06-29-2009 08:38 AM
Hot Rod Steering Column klutchmaster427 Suspension - Brakes - Steering 5 06-10-2009 02:27 PM
Steering column ID tgifford5 Suspension - Brakes - Steering 1 09-09-2007 08:30 PM
GM Steering Column buckethead1 Electrical 5 07-28-2006 06:50 AM
Steering column help 302 Z28 Suspension - Brakes - Steering 3 07-11-2003 11:28 AM
