steering column 34 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2007, 05:33 PM
Last journal entry: 34 Finally
I know this question has been probably answered a thousand times but here goes. I have been looking in local graveyards for a suitable steering column for my 34 five window.Some have suggested the 1988 up Chev. Camaro. Why not the previous years? Found a "virgin" 1983 Camaro tilt and wondering why not? What length column is preferred? I know the early Chevy. van columns are often chosen but are tough to find. I really don't want to just "buy" an aftermarket and install it..kind of like doing things my way!
Old 03-26-2007, 05:38 PM
boatbob2
steering column
hi,i used a column out of a 87 firebird (same camaro) in my 34 ford pickup. fit good .Im boatbob2
Old 03-26-2007, 06:06 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
What I do to determine the length column that I need is to mock it up....Put a set in the car and us a broom stick or someting and run it through the floor or fire wall at the proper place for a steering column see where you would want the steering wheel to be...mark it on the broomstick and then measure it. I used a tilt column out of a Camaro for my 30 Ford coupe.
Old 03-27-2007, 03:15 AM
staleg's Avatar
Last journal entry: Hand brake
I'm going to use a column out of a '90 mod Chevy Astro in my '34 Roadster. Hope it fits...!
Old 03-27-2007, 07:23 AM
302 Z28's Avatar
I have found that a column of around 32" fits pretty good. I did have a column out of an 88 Camaro and it would have fit fine, but I was at a loss as to how to cover up the funky looking ignition switch showing at the bottom of the column. I did not want to use some goofy looking carpet or upholstery boot. I eventually sold the Camaro column and went with an Ididit. Much nicer looking and fit perfect.
Vince
Old 03-27-2007, 07:59 AM
I am with Vince ...
The later columns look overly large and out of place ... to me
in a small early car. The van columns may cost a little bit more ... but fit perfect, and look more at home in a early car. I used the early van column in both of my 32's ...
The Ididit is a nice, quality column ... but I wanted the painted look in my car ... plus I already had 4 or 5 of them ...
50 Ford Tudor Pwr Steering Conersion Schenkeinstein Suspension - Brakes - Steering 5 01-29-2010 05:58 PM
34 ford steering coloum blklar Hotrodders' Lounge 4 10-27-2006 09:16 PM
Steering column woes gr8art Suspension - Brakes - Steering 6 09-14-2006 03:34 PM
Need Help Moving Steering Column! KernCountyKid Suspension - Brakes - Steering 11 08-31-2006 01:05 AM
EZ-Wire : Reading Wires From Steering Column horvath Electrical 2 03-23-2003 05:56 AM
