Steering Column - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2004, 04:26 AM
Steering Column
I got a 52 Ford pick-up with a Toyota power steering box. I'm looking for a tilt steering column with NO shifter, key, or gear indicator. Got a floor shifter, key on the dash. I'd rather use one from a donor, than spend big money at Flaming or Ididit.
Old 09-04-2004, 06:02 AM
As one of the Moderators here.........let me be the first to WELCOME you to this board
I had a 48 F1 years ago and I used a 66 or 67 GTO tilt column.
No shifter
No key
No indicator
It was small and looked like it belonged there.
It had canceling turn signal switch and took a GM steering wheel adapter kit from Grant....I wanted to use a Grant (after market) wheel.
Most all GM vehicles went to the key in the column in 1969......except trucks and vans.
DEUCE.....General Tech Rodding Moderator.
Old 09-05-2004, 04:12 AM
Thanks Duece. One more piece of the puzzle solved.
Old 09-19-2004, 07:57 PM
I couldn't find a '66-'67 GTO steering column, the best I could get was a '74 Firebird tilt column with keyswitch (with keys) for $28. New problem...I have a '84 Toyota PS box with universal joint and the bottom half of a rag joint, the new column end is a 1" diam spline shaft. Is there any way to 'marry' these ends together? Does GM make a 1" inner diam rag joint? The idea of grinding or welding doesn't appeal to me.
