One of the members here swears by the Chevy van columns..........Speak up Deuce.
Ontario Rodders |
I wanted the same "clean" look for my 55.5 Chevy truckrod. Same front suspension/power steering as yours. I used the original steering column, shortened it about a foot, added a lower bearing to stabilize it, and "resplined" the end of the column shaft with a grinder. I basically grinded a double-D to the end of the column to mate with the Flaming River u-joint. Fairly simple.
Hope this helps. Antny |
Guilty ... I use a Chevy/GMC van tilt whenever I can. If you want a column with a column shifter for automatics ... I believe these columns are the best suited ones I have found. They are about the right length and are small. They have tilt if you want that ( available without it also ) and have a P R N D L2 L1 on the indicator. No key ... but does have turn signal function. Also uses the standard Chevrolet wheel spline so lots of aftermarket choices available for the steering wheel.
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
I am kind of leaning toward the original column. I am trying to do the car so it looks, besides the wheels and engine, stock, or at least the mods will be seamless so that you can't tell what is different
Mark |
Flaming River!!!
You can't go wrong with the stocker if you want clean and plain! I have a hard time with not having turn signals on the column though! I'm not a big fan of the van column indicator(sorry deuce) But the best part of street rodding is that there is no "wrong" set up,because you taylor it to your likes and dislikes! just make sure it is safe.
Now I see why people like the van columns so much. Stupid question....How do you run a horn with the aftermarket wheels?Do you have to run a seperate switch or doers the whole wheel become the horn button.
Shane |
This is the one I used in the 32 roadster. Different wheels or different columns requires different kits.
Everyone one his or her thing. I like them because I do not want a shifter in the floor, so a column shifter is must for me. IF you have a column shifter ... you need a indicator IMHO. My wife drives our street rods and also ... you MUST have a shift indicator to pass the NSRA safety 23 point inspection. LOOK in the lower right hand corner of the windshield and you will see the sticker on my 32. ![]() You car must have a "Safety 23 sticker" to win a award from NSRA ... and NOT boasting BUT I have won several awards at different NSRA events.
Shane |
EDITED ... getting off topic and no tech merit ... sorry guys ...
Last edited by Deuce; 02-12-2008 at 06:39 PM. Reason: Violation of guidelines. Please see: general board guidelines. |
Now LET'S get back on topic ... please ...
Funny jokes and comments belong in the Lounge Thanks fellows ![]() Deuce
O.K. sorry about that one, I could'nt resist! back to the topic, I have used the stock type columns in early ford applications by shortening them and adding a bearing or nylon bushing at the bottom, and pinning a u-joint and tacking it as well. (customers love the 39 ford type column, but since the horn wire passed through the steering shaft and was connected through the steering box, I have had to come up with some bizarre solutions. I have not had this problem with the early chevrolet columns but you do need to consider that turn signals horn and 4 way flashers are not available on the early/original columns, and adapters are scarce for them as well!)
| '39 ford steering column and wheel | jim williams | Suspension - Brakes - Steering | 5 | 07-01-2010 09:38 PM |
| Steering Column Install | Quarter Flash | Suspension - Brakes - Steering | 3 | 05-10-2007 11:36 AM |
| Steering Column for 1971 Chevrolet C/10 | glayman | Suspension - Brakes - Steering | 13 | 02-24-2007 01:08 PM |
| Steering Column Wiring | loiselle | Electrical | 3 | 05-16-2006 10:08 PM |
| Steering Column Harness on a G-body | 1982 SS | Electrical | 2 | 07-29-2005 01:06 PM |
