steering column conversion 1957 chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2003, 11:23 AM
What, if any steering columns will replace the original column in a 1957 Chevy pickup? The easier the conversion the better.
Old 11-03-2003, 12:02 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Most pre-plastic GM columns can be made to fit fairly easily. Use the under dash bracket and the column. You will need to modify the bracket to fit under the dash between the dash and the firewall. I installed a mid-70s Monte Carlo column in a '57 Chevy pickup. The car was a donor for it's front clip, the steering column and the power brake unit.
Old 11-06-2003, 04:36 PM
ShamrockCustoms's Avatar
Lover of Classics and Customs
you can also put in a column from ididit, flaming river, or billet specialties.....i'm putting a billet specialties aluminum column in my 56 along with some borgeson aluminum goodies......
good luck!
