Steering Column Harness on a G-body - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2005, 10:43 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
I have found I have an intermittent electrical gremlin that seems to be there more than not. I was coming home from racing last friday and about halfway home I noticed my volt gage was low (lower than 10 volts). I drove a little further and my voltage came back up but went away slowly. The voltage appeared to come up when I hit a bump or rough patch of road. I parked it overnight so I could actually work on it. I found the output wire's lug's plastic insulation to be melted. The rubber boot that covers the lug was also charred.
I was just working on it when my father said maybe the problem lies in the steering column. Now, my steering column has been loose for awhile but has just become real loose (up and down has over 1" of play vertically). I can grab the steering wheel and shift it side to side and up and down quite a bit. I was checking the alternator output wire and the wire with fusible link from the starter solenoid and had continuity to ground. I wiggled the wheel and was able to close the circuit(s) so I no longer had continity to ground. This wiring is all stock. Is there a chance that maybe I have an intermittent short to ground in the column that is pulling some good power?
Vehicle is my 82 El Camino. I have the factory wiring diagram in the factory service manual. All the wires under the hood seem to be in fine shape. as is the wiring that I can see under the dash to the column. There was no smoke or fried insulation smell inside or anywhere so I don't think any insulation was burning.
Recap:
Intermittent short. Steering wheel moves...alot. I had continuity to ground, wiggle wheel, circuit closes and no more continuity to ground. Could steering column area/ignition switch be the problem?
Old 07-29-2005, 01:25 PM
SinistrV6's Avatar
valve monkey
Can't help with the wiring but...
heres a good "how-to" article on tightening up the column.
http://www.gnttype.org/techarea/susp..._steering.html
HTH,
Richard
Old 07-29-2005, 02:06 PM
1982 SS's Avatar
Flamethrower
Cool, I'll take the column apart and see what I can see for nasty wires. I have been needing to tighten it up anyways.
GM steering column tilt/wobble repair HELP (pics inside) camaroguy1969 Suspension - Brakes - Steering 18 03-05-2009 01:37 AM
steering column shaft moves RodFather Suspension - Brakes - Steering 11 01-13-2005 05:13 PM
Steering column ?'s Bluepen Interior 4 01-03-2005 11:44 AM
steering column buckely53 Suspension - Brakes - Steering 3 12-10-2003 08:50 PM
Steering Column Dress-up Kit Bill Ford Interior 1 06-11-2003 03:43 PM
