steering column help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2005, 08:57 AM
stea's Avatar
Im using a 66 buick steering column in my project. I'm reassembling after paint and on this column it uses a sheet metal band with a pinch bolt that goes around the 3/4 shaft at the base. Its next to the lower bearing to secure the shaft in place so the whole shaft wont pull up. The band is trashed and im looking for another alternative. Maybe some sort of collar that secures with a set screw. Any idea where to pick up something like that?
Old 01-11-2005, 09:15 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
just go to the bone yard & take one off of any other GM car or truck, they should pretty much be the same, at least the one i have seen were..joe
o yea can ya show us a picture IF i'm wrong w/what i think ur talking about
Old 01-11-2005, 09:31 AM
stea's Avatar
Looking for something new, possibly in stainless or aluminum so I can make it purdy. Ill take a pic tonight when I get home.
Most hardware stores carry shaft collars with a set screw in them for a couple bucks.
Old 01-11-2005, 10:21 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
I have used a two piece billet Alum. heater hose clamp, they work good and look good. Any hotrod supply place should have them.
Troy
Old 01-11-2005, 03:19 PM
stea's Avatar
Thanks guys. I checked a couple hardware stores and they had them in steel. Went to a local bearing supply store and they set me up with a stainless piece. have to wait a couple days but Im still waiting on my ujoints anyway.
