Steering column ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2007, 09:39 AM
Steering column ID
I have a 69 camaro with a steering column that is not one found on that particular year car. The turn signals and hi/lo beam are in the same lever with a cruise control switch and it also has a tilt lever. All I can see for id numbers stamped in the column are A-8 or 3 on the bottom of the column near the firewall. Can anyone give me a hand in iding this column or send me where I can check column id numbers? It was suggested to me that it might be an 80's - 90's column. Thanks.
Old 09-09-2007, 08:30 PM
WELCOME to Hotrodders.com
GM did not start installing the HI/LO beam switch on the column until the late 70's or early 80's ... so the column would be in that era. 69 Camaro tilt columns are difficult to find ( and expensive when you do ) so the previous owner most likely went to a newer column to gain the tilt feature.
Without a photo ... Identifying the column is very difficult ... but I would guess it is a late 70's to early 80's Camaro or Firebird column.
Again ... WELCOME
Deuce ... Moderator
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
76 Monarch / Granada Steering column in 55 Fairlane Rons1stRod Suspension - Brakes - Steering 1 08-22-2007 10:58 PM
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 11:36 AM
Steering Column for 1971 Chevrolet C/10 glayman Suspension - Brakes - Steering 13 02-24-2007 01:08 PM
Steering Column Harness on a G-body 1982 SS Electrical 2 07-29-2005 01:06 PM
