Steering column for my '29 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2006, 10:51 PM
Last journal entry: hot rod axle
Hey guys,
It's time to move the steering from the center of the roadster to the left and I need some advice on steering columns.
The steering box is Corvair so can I use most any GM steering column? Do I just go to the pick and pull and start measuring?
I'd like to use a pre-'69 column so I don't have that cheezy ignition in the column thing, and I have access to some early GM pickup columns. Will they work ok?
Is this more simple that I'm trying to make it?
The car is basically a highboy '29 so if there are any off you guys out there with experence with this I'd really like to hear from you.
Check out my project journal, Mike Britton's project journal, and you can get an idea of the geometry of the steering. Thanks
Old 12-30-2006, 11:32 PM
PRO 48 fleetline's Avatar
Last journal entry: Csr Electric Water pump
Sounds like a cool car
I just purchased an ididit column for my 48 chevy and would recommend the purchase, heres why its something thats A important your steering
plus i just sat mine in for mock up and turned it its soo smooth all new peices you can get it with out the ignition or shifter like mine plus they make a shorty version for small hot rods liek yours,
again depends on the wheel your running aswell my im workin on a 32 model A 60 hot rodd and it has a simple straight old column with a 39 chevy wheel but if you want a GM style column to run with the many after market steering wheels i recomend ididit great stuff
the version i used in my 48 is for a 55-56 chevy so i could runu the 56 del-ray steering wheel to follow the them for my car
ID:	17280   Click image for larger version
ID:	17281   Click image for larger version
ID:	17282   Click image for larger version
Old 12-30-2006, 11:36 PM
steering column
Thanks, I was hopin to keep away from the big money of an after market column, but it might be worth it for so much less hassel.
Old 12-31-2006, 01:09 AM
yeah there worth the investment, plus you dont have to smooth the column to get rid of the key and shifter knobs been there done that on my nova this one i bought good luck on your build plus i think i had right at 3 hundred in this one went to summit and picked it up had it in stock plus they come with the billet levers etc
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 10:38 PM
Steering Column Wiring loiselle Electrical 3 05-16-2006 11:08 PM
Steering Column Harness on a G-body 1982 SS Electrical 2 07-29-2005 02:06 PM
custom steering column Blob Suspension - Brakes - Steering 5 07-08-2005 02:28 PM
best steering column for 29 Ford street rod pikalpha Suspension - Brakes - Steering 5 11-28-2001 11:54 AM
