Steering column questioN???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2007, 02:57 PM
zeitlerusmc's Avatar
I have 1963 chevy truck and I'm going to be converting to and auto and also going with a cadi theme, I have put cadi seats in it and I also wanted to do some cadi quages and steering wheel, but my question is does anyone know of a whole cadi steering column that would work in my 63 c10????
Old 02-05-2007, 10:27 PM
Just pick one. Tilt or tilt/telescope. Make sure it has keys, at least one that works. If you're looking for a column shift fit that one, no shifter find that one. Be sure the wiring plugs are there. If you're taking it out cut the the car wiring harness back as far as you can from the plugs and leave 'em plugged in on the column.
Old 02-08-2007, 09:24 PM
Last journal entry: Silverado Project
No Keys?
If there isn't any..the unit could be cheaper, take the whole unit to your nearest lockmith shop, have them either put anouter new lock with keys in it, or have the ignition keyed up to your doors using your own keys....simple concept I know...
Power Steering conversion question / Bump Steer robin58 Suspension - Brakes - Steering 4 08-12-2005 09:02 PM
Steering box question Ratoflic Suspension - Brakes - Steering 1 04-27-2005 03:14 AM
Steering Wheel Adapters Question horvath Interior 17 06-26-2004 06:50 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
Steering column question Bluepen Suspension - Brakes - Steering 12 07-31-2003 06:52 AM
